Выберете то, что вам нужно
Disconnect the hard drive SATA power and data cables from the motherboard.
Почти готово!
Заключение
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Taiji Saotome - Ответить
Thanks for letting us know about when the open day is going to be. Will make sure get my work completed by rushmyessay before the day so I can attend it in peace.
shuaib ahmd - Ответить
