Введение
Follow this guide to remove the hard drive from your Xbox One, and follow it in reverse to install a new drive.
Depending on the firmware version of your Xbox One, your console may or may not be able to format the replacement hard drive for you. Older firmwares cannot format the hard drive, while newer firmwares can.
If your Xbox One console is not capable of formatting a replacement hard drive, before you install your replacement drive, you will need to reformat the drive in a computer and install the necessary software, following this technique:
Выберете то, что вам нужно
Видео обзор
To open your Xbox, you're going to have to cut or peel up this tamper-evident tape. But don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
Use a plastic opening tool to pry up and remove the plastic vent that surrounds the side USB port.
The vent is fairly flexible, and held in place with weak plastic clips—start prying from the back and peel it out.
- 플라스틱 오프닝 도구를 애용해서 측면 usb 포트를 둘러싼 통풍구를 들어올려 분리하세요.
- 이 통풍구는 무척 유연하며 연약한 플라스틱 클립으로 고정되어 있습니다. 뒤쪽에서부터 들어올려 분리하고 떼어냅니다.
Slide the tab straight back and remove it.
Here is What's Stated in Step-3 : (There is a small plastic tab that reinforces the front corner of the Xbox.) Actually, the "Tab" is NOT SMALL at all. See the Picture: The "TAB" is the Piece that this Person has their Thumb on, is the Tab that you NEED TO SLIDE TOWARDS THE "REAR" of the Unit. You will be able to tell How this Large Tab Holds the Top and the Bottom Case Covers together. Take Note how to Replace this tab back where it Belongs, when you are putting the Case Covers back together. Hope that this comment will help you. 6-29-2017
- xbox의 전면 모서리를 지지하는 작은 플라스틱 탭이 있습니다.
- 뒤쪽으로 똑바로 밀어서 제거하세요.
What is this small tab referred to as?
What is it called i need to order one.
Insert the flat end of a spudger between the upper and lower case where they meet at the rear of the side vent opening.
prying does not work. my spudger is causing damage. my soft. plastic. spudger. and the %#*@ thing does not move. this is a common issue with the instructions on this site. you write instructions like you assume people have extensive repair experience. describe the plastic tab. add detail. because simply prying WILL damage the case. hire a %#*@ writer. cause you guys do not know how to precisely convey important detail. constant problem with tech companies actually. no writers.
- 벗겨낸 통풍구쪽부터 상판과 하판 사이의 틈으로 spudger의 평평한 끝을 밀어넣습니다.
- 플라스틱 클립들이 꽤 강하기 때문에 생각보다 강한 힘을 사용해야 합니다.
- 케이스를 완전히 열 때까지 spudger를 계속 끼워두세요. 클립이 강해서 작업도중 다시 닫힐 수도 있습니다.
it would be very very nice that the part, that you sell, will Fix. This an ols Tutorial. The new opening tools that you sell, will not help anything, cause there is no flat sign on the side. you link these tools at this tutorial, but never tested, if the new tools work. so i tell this you, no they dont fit. Thanks for nothing.
I ve made it this far with only a Lego membership card and a flimsier amusement park card (I'm a big year old)
I had to use a 1/32nd flathead screw driver. In the corner to get it started push the top joint of the case down and up will simultaneously pulling up and down to seperate the seam. You will need a 3rd hand to insert the 1/32nd flathead and pry up to get the case started.
I had a virgin never opened xbox day one og so that might be why I had to do it this way.
even the wikihow instructions are better
It’s easier if you push the top empty area part of the plastic with your finger, and stick the spudger about 3/4” (2 cm) away from the back of the xbox and start prying. You have to do this because that is the only spot where there are no clips in the way. If you do any less or more distance, the clips are in the way, and you’ll never be able to pry open the Xbox because the tool can’t get in.
A youtube video I found explains this step better. You are meant to pull up on one half and push down on the other, this separates the two halves. Then use a spudger on the rear of the console to separate the clip right under the warranty sticker, then move down the back of the console to the other clips
Insert a plastic opening tool between the upper and lower case to separate the clip over the rear vent.
- 상판과 하판 사이에 끼인 후면 단자판은 여러개의 클립으로 고정되어 있습니다.
- 플라스틱 오프닝 도구로 후면 통풍구의 클립들을 분리하세요.
Keep moving along the rear of the Xbox, prying up clips.
- 후면을 따라서 계속 클립을 들어서 분리하세요.
- spudger가 제대로 꽂혀 있는지 중간중간 확인하세요. spudger가 빠질정도로 케이스가 분리 되더라도 남은 클립들이 매우 탄력적이라서 방심하면 도로 닫히기 십상입니다. 원활한 진행을 위해 spudger가 잘 꽂혀서 사이를 벌리도록 유지하세요.
Keep popping clips. It may help to slide the plastic opening tool across the clips.
- 클립들을 계속해서 분리합니다. 클립들을 가로질러 플라스틱 오프닝 도구를 주욱 미는 것이 도움이 될수도 있습니다.
- 후방 케이스를 따라 분리하면 상판이 열릴 기미가 보여야 합니다. 만약 열릴 기미가 보이지 않는다면 모서리부터 플라스틱 오프닝 도구로 분리를 시작하고 usb포트가 없는 쪽을 따라서 클립 분리를 다시 시도하세요.
Starting with the spudger you left in the crack, pry the upper case up to free the last few clips.
Lift the upper case slightly and shift it to give access to the front panel board.
I got confused here. I couldn’t unclip the front panel at all. I found out that if I open the case like a clamshell (or a book, with the front being the spine of the book) I popped right off easily.
Yeah, I saw your comment afterwards but this is exactly what I ended up doing as well. just a note for anyone reading this be careful of the flex cable as it does seem to put a questionable amount of strain on it when you open it in this manner.
Use tweezers to lift the blue plastic retaining loop over the white connector on the board.
Use the tip of a spudger to push the connector's locking tab toward the cable to unlatch it.
Or anyone else who has this problem or reads this on this thread, which is not the correct thread for this question by the way, here is a link to the forum for that. It could be any of a number of issues including overheating, Portland elation, or infestation, among others.
Is there somewhere that I can buy a replacement zif connector
Use tweezers to pull the cable straight out of the connector on the board.
Remove the upper case.
Use the flat end of a spudger to free the clips securing the front panel to the upper case.
Remove the front panel from the rest of the upper case.
Replace the top part of the upper case.
Line up the clips and press firmly to re-seat them around the perimeter.
Support the front panel near the front of the Xbox.
Use tweezers to replace the front button cable in its ZIF socket.
Use the flat end of a spudger to push the ZIF lock to the left to secure the cable.
My Xbox stopped working after this thanks
Mine did as well, its possible it may be the same reason. For me I had to unplug and plug it back in a few times and then clean off the contacts with isopropyl alcohol. Seems simple but if you haven’t already, I would try it.
With the front panel at a 45 degree angle, interlock its plastic hooks with those in the lower case.
Push the top of the front panel into the Xbox, like closing a mailbox. Press firmly so that the clips securing the front panel to the upper case lock securely.
Gently pull up on the speaker cable connector to disconnect it from the front panel board.
Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
If this connector is broken off, will that prevent the control panel to not work at all and NOT turn on? Is there a fix or work around IF this connector is broken off?
Remove the two 9.5 mm T8 Torx screws from the WI-Fi board.
Lift the Wi-Fi board straight up from its socket in the upper metal case.
Leaving the Wi-Fi board antenna cable in place, move the Wi-Fi board aside, exposing the screw labeled "C3" that was beneath it.
When reassembling- put the outer ones on first to secure the port to the metal. Then putting the wi-fi board into the port will be easy
The T9 fit but was a tad big, for me the T8 worked fine
Where can i get a T9
Remove the eight 65 mm Torx T10 screws from the top of the upper metal case.
Lift—but do not remove—the upper metal case.
Disconnect the Wi-Fi board interconnect cable from the motherboard.
Disconnect the hard drive SATA power and data cables from the motherboard.
I found that it is not necessary to take out the hard drive in order to remove the front panel module. If you can lift the whole metal enclosure a little to get to the right most torx screw, then you do not need to move the hard drive.
Thanks for letting us know about when the open day is going to be. Will make sure get my work completed by rushmyessay before the day so I can attend it in peace.
Remove the four 8.5 mm T10 Torx screws securing the hard drive assembly to the hard drive tray.
Unplug the SATA connector block from the hard drive.
bullshit. konsole kann die festplatte nicht lesen. also nutzlos der mist hier!
Wie heißt der stecker
229 участников успешно повторили данное руководство.
88 Комментариев
I've managed to open my Xbox one, tested the hard drive and it has failed (error scanned and it's 90% bad sectors). I've got a new harddrive for it, but can't find where to get the correct software for it/ how it needs to be formatted. You mention this info at the start of this repair but cant see a link to the software.
If there are no links, would cloning another xbox one harddrive work as a repair?
Ah, Sorted now. I managed to clone another hard drive. This doesn't work right off you still need to apply an update via a pend rive. But once this is done, the hard drive does pick up and work.
What Hard Drive did You Clone? My Hard Drive failed Aswell.
Please see my Xbox One HDD Replacement Wiki to solve your issue (scroll to very bottom): http://jw0914.github.io/Wikis/
JW0914 -
I haven't done this yet but I, like most other people won't want to lose any saved games etc. How do I do an exact copy from the current HDD to the SSD I'm putting in? Thanks!
Hi,
how do you make the copy from HD to SSD?
You'd need to make a WIM of Partition 2 (User Content). I'm not sure about pictures/videos, but I would imagine they'd be redownloaded once you sync your Xbox Live account by logging in, just like everything else (licenses, games, etc.). You'd have to verify that however.
I go over how to create WIMs of the partitions in the Xbox One HDD Replacement wiki I wrote, which can be found on my GitHub (scroll to very bottom): http://jw0914.github.io/Wikis/
JW0914 -
Just use a software like Paragon Partmanager to COPY all sectors (not alla files) with the exact geometric data status.
Could anyone complete the guide by explaining how to image a drive or any other special actions that need to be taken to get things up and running? (links if needed)
Xbox One HDD Replacement wiki (scroll to bottom): http://jw0914.github.io/Wikis/
JW0914 -
Does the Xbox One accept any standard SATA II hard drive? Or does the OS place restrictions on certain hard drive models/specs?
I'd just like some direct confirmation on the matter. I get varying answers on Google, mostly outdated from many months ago.
I have used hard drives other than the OEM ones with great success. The issue comes with using a 1TB drive. The original script from my experience doesn't accurately produce a working 1TB drive compatible with the newer firmwares and always leads to E203 or E204. I was able to modify the scripts and the methods and can successfully use any 500GB or 1TB drive. On a side note you don't need to copy anything from the original drive unless the console is in the preview program; even then you only need the contents of the System Update partition nothing else. Just format/prep the drive on PC, run the correct OSUDT from Microsoft then restore to factory once you see the dash.
So what exact files do you need to boot a new xbox one hdd, and where do I find them?
It depends on if the the console is in the preview program or if the firmware is corrupt.
If the console is on standard firmware then you don't need anything off the old hard drive. Simply format a hard drive and put it in the console and use the correct OSUDT from Microsoft. When complete, factory restore the console. If the console is in preview or corrupted; format a hard drive and copy the contents of the System Update partition (NOT System Update 2) to the new hard drive. Then simply use the reset USB files from Microsoft.
If for whatever reason you aren't sure which OSUDT to use you can always copy the System Update partition contents from the old drive and then use the reset USB. During the initial setup it will download and install the relevant update.
So my xbox got corrupted and so I am trying to just redownload the os, what format do is use? ntfs? I don't need any of the data from the corrupted hdd. Do I use the offline system update file that is named "$system update" and only have that on my hdd when i reinstall it? Does it really matter which OSUDT I put on it because I have no clue what it was running before it crashed. Thanks for any help
You'll need to format the new drive using linux (any live distro should do) using the scripts mentioned in the video, available on github just google "xboxonehdd". Just follow the video at the top of the guide to format; run mkxboxfs.sh and then run xboxonehdd.py
OSUDT does matter. If you use the wrong one it will give you an E101 error. If you can remember if you have the newer windows 10 layout (sidebar on the left) use OSUDT2 otherwise use OSUDT3. If you don't want to do that just or your console is in the preview program copy the entire contents of the System Update partition from the corrupt drive to the System Update partition of the new drive and use the RESET files not any of the OSUDTs. OSUDT and RESET files should only ever be put on a USB not the hard drive as the files are not the same.
Will I be able to format this using windows 10? Could I clone the previous drive's partitions, delete all of the partitions then just only have the update file and A and B on it?
And I have zero knowledge of linux, but if I have to use it, is it possible to boot it from a flash drive or something?
You could format it with windows as long as you can create partitions at the correct starting sectors and of the correct sizes. You would also want to be able to GUIDs of the partitions. Easiest thing is to download Ubuntu from their site. Create a Bootable Live USB using the installer they provide. Boot into linux, download the scripts from github and run them with terminal. Linux knowledge needed is minimal providing you know how to change directory in a windows command prompt. All commands should be in the video at the top
Hello can provide folders A and B?
danilkk2 -
No as the contents of the A and B folders are different for each system update so you would need the folders for your consoles firmware version. Unless the console is in the preview program just leave the whole drive blank and install the OSUDT and it will create the correct files/folders during installation.
My system is stuck on the latest update and I am getting the E101 errors with any of the OSUDT versions. Following various posts, I formatted the "System Update" partition on the hard drive but I must not have copied the A and B folders over correctly to my computer because I cannot locate them. In an attempt of hope, I have recreated new (but empty) A and B folders and added the updater.xvd file to the partition. If I run the process again with the OSUDT2 from a flash drive, will the Xbox update put the necessary files in the A and B folders and finally update the system?
Please see my reply to Genesis730
JW0914 -
FIXED!! thanks so much for this guide.
So, I had the preview software and green screen of death for an hour followed by error message screen.
read all your posts above. thanks to all!
what I did was connect the hard drive to the laptop and format each partition (lost all my games but whatever can redownlaod) BUT for the system update partition I followed the advice above and copied the A and B folder and pasted them back after the format.
So then I put the drive back in and used the usb factory restore method and boom!
The reason I went through all this is that the usb diagnostic tool factory restore was not working AT ALL even after much help from Microsoft support. All they could say after exhausting all options was return it and get it fixed/replaced but I don't live in the US so would have been a pain.
thanks again!
MrStubbly, would you care to share your modified script that does work for a 1TB+ drive. I have had success in the past but am currently not getting anything to work.
I have formatted and setup my drive like this:
- Formatted drive in Disks
- Ran python script (sudo python ./xboxonehdd.py sdX)
- Ran sudo bash command
- Added files from my working OG System Update partition (Contents of Folder A, Folder B, & updater.xvd)
- Ran python script again (sudo python ./xboxonehdd.py sdX, and confirmed with 'yes')
- Copied OSUDT2 (And OSUDT3 as well. I assumed it should be OSUDT2, since I have the newer Win10 tile based home screen but tested both for S&G.)
- Powered off my XBOX, unplugged it for about 15sec, plugged it back in, held both BIND & EJECT before powering on the system and continued to hold until I get a notification sound.
The end result of any test is that I get the E101 error.
Any further advise or help you, or anyone, could provide would be great! Thanks
It seems all tutorials miss a few things... the issue you're having is due to how the OS rebuild occurs. When the rebuild occurs, Windows will wipe and repartition the HDD if it's partition structure is different than the HDD it shipped with, which wipes the rebuild files, thus a 101 error is received.
Because no tutorial gives accurate instructions on how to rebuild the OS, I created a wiki that can be found on my GitHub (scroll to very bottom): http://jw0914.github.io/Wikis/
JW0914 -
I can't get this formatting to work! I wish there could be a correct video guide to this problem. (Using a 1tb hard drive)
As the articles said, This console cannot format a drive, even though being a CPU and it could do it technicall. Ask for this to Jewish Developers and builders who intended to forbid this command or this option. I am sure You won't have the answer.
So if I'm on the preview program and I im trying to setup up a brand new hard drive(because my existing one died) what should be the process?....also when i do everything ....i've turned on the xbox one and get nothing just a black screen....is it possible i've done everything right and i just need to reset the video settings?
My hard disk is damaged and I can't access any file. Is there something that I can do?
The statement in the OP "Your Xbox One console is not capable of formatting a replacement hard drive for use as the main drive." is factually inaccurate.
The Xbox One stores the EFI boot partition and Recovery partition (containing WinRE) on the NAND flash, as well as most likely as vhd containing cli programs and scripts. Provided the GPT header has been modified in Linux prior to installation into the XB1, the XB1 will auto partition and format the HDD to the original partition layout of the original HDD that shipped with the unit
If it shipped with a 500GB HDD, and one installs a 1 or 2TB HDD without utilizing a separate script written by Juvenal1 on GitHub, the partition layout will utilize 465GB for the 5 partitions with a 465GB unallocated space after partition 5
Hi
First of all, thanks a lot for the guide.
I have an Xbox one with the hard drive with errors because of a bad update, I tried all the stupid solutions from Microsoft and none work. So I am going to change the hard drive, My question is: A friend has an Xbox one that is not working because of other problems, but the hard drive works perfectly, so I would like to know if I can put the hard drive from the Xbox One from my friend into my Xbox One with the failing hard drive and if it would work right away
Thanks for the help.
Hello I am in a preview program xbox one. My internal hard drive broke, replaced it with a new but not working no operating system.
These options with OSU1,OSU2 not work for me.
My OS 14393.2072.amd64fre.rs1_xbox_rel_1610.160920-1900
I'm a Xbox One regular owner on preview program. I have a question.! I dont have any files from the System Update Partition to recover my console from those EXXX errors
What I know is that I have a friend who has a Xbox One S on the latest Preview , working perfectly.
Can I copy those files from his Xbox to mine? is there any difference between the files of a Xbox One S....................
I wrote a guide with a newer / easier method to clone a drive: https://adcurtin.wordpress.com/2016/11/0...
Just follow your guide and work well. Thank you
Replace the internet WD 500 GB with SEAGATE ST95005620AS 500GB and right now playing FF XV :P
imbasd -
i attempted the clonezilla method as described and receiving errors on the source disk that its scheduled for a check or shutdown uncleanly. any suggestions?
Can anybody tell me which hard disk to buy for my xbox one as a replacement?
My stock XB1 HDD is a Samsung 1TB. And I tried the 500GB HGST HDD which pulled out from my PS4, it also work. And I upgrade it to the Seagate Firecuda 2TB SSHD. That also work flawlessly.
In the video it says that you can no longer do this after the December update. Is this still the case? Can I not upgrade the HD anymore?
Thanks,
Jake
Don't worry, you can, I just did that yesterday with the most up to date dashboard.
Hi I need help, I mistakenly formated my original Xbox one hard disk and I lost everything, please can anyone email me his system update file so I can clone a new hard disk for it?
My email is erickekesi3@gmail.com
No need, I just did the upgrade without any files from the old HDD.
I suggest you do the following.
1) hold down eject + bind buttons, tap the power button to boot (keep holding both eject and blind button) until heard the 2nd boot sound effect.
2) choose factory reset in the diagnostic manual. After reboot, shut down.
3) use the Windows script to format the HDD. No need to copy anything on it. I tried it myself. 100% sure no need those folder A, folder B... the HDD can be 100% clean.
4) go to the Xbox support webpage and follow the steps about boot with error E205. It will lead you to the download the correct OSU.
5) format a USB drive to NTFS
6) unzip the OSU and copy that folder (with all files inside) to the USB drive root folder.
7) install the new HDD
8) plugin the USB drive and Ethernet cable
9) hold down eject + bind buttons to boot until the system update start.
After step 9, your machine should go back to the init state with the new HDD.
Just finished the 2TB SSHD upgrade base on this guide. However, step 4-7 is hard. With some research, I found that 's actually much easier to open up the XB1 by pressing the correct "pressure point" to unlock the clip. Just press the correct position, hear the "click" sound, then move on to the next clip. Apart from that, this guide is good. I cannot remove the wifi board connector (step 19) because it's very firm, and I don't want to apply hard force on it. But it won't affect the HDD swap, I can just open the top metal with the cable still connected and take out the HDD.
I highly suggest that swap the HDD, install only the front cover and connect ALL cables (zero screw required) to do a boot test. Only reassembly the XB1 if it can function normally. Otherwise, there will lots of work to take the HDD out and re-format it again.
Apart from Linux, there is a script for Windows to format the HDD, and I do everything via a virtual machine., extremely handy.
I have been trying for several days and in many ways and all without success, your informed process, I am hitting this button, I already achieved a triumph the console created partitions with 2tb and left 1600gb for games, before it formatted my 2tb hd as if It was 500gb and left the %#*@ 362gb, I will continue to try, I will not give up, my console is open for 10 days, I am from Brazil and I spent money to get a 2tb firecuda, and it will not be now that I will give up. Thanks
Hello I followed the guide with a new hdd after update failed on old hdd. When I placed clean hdd in xbox with folders a and b with updater. The xbox remembers it's progress in update and fails in same place any help would be great
The new fall release has caused many XB1’s to fail as well as 2 of mine. I’ve tried a brand new clean drive with no resolution. Gets stuck @ 58% and goes back into error code 100. Going to try a few more things and if it does in fact work, I’ll be updating my original post with a working solution.
So I tried to swap a hard drive from an Xbox one to an Xbox one S. The hard drive from the original Xbox one had a ton of games that weren't mine (I bought the Xbox from someone else with 60 games downloaded on it, minus all of my games that I had already owned). Anyways, I swapped them over no problem but now neither console will load entirely. I get the booting up xbox screen for 5-10 minutes then it loads to a blank screen. I can hear audio and I can turn it on and off via the controller but the video output seems to not be working right. (Even after swapped the hard drives back to their original consoles). Am I screwed?
This is a massive disadvantage to the ps4, on an x box one you have to open the hole console and that voids your warranty!!!
Guys i think you should check XFIX the new video and windows script he has provided is brilliant and he has made xbox one hdd swap alot easier
Thank you so much for this awesome guide on replacing the HDD. My Xbox is up and running with no issues.
After upgrading a dead 500gb HDD to a new 1TB the system install gets to 33% applying update / 71% overall and then returns error E102. Anyone know what’s wrong and how to fix it?
Hey, I’ve been reading these comments and noticed as the years changed that it gets more difficult to install a new HDD/SSD in the Xbox one. As you can see it’s 2018 from my post and I really curious as to if this process still works?
I have a OGbox running preview dashboard, my question is can I just format the new drive I want and put it in the Xbox?
or do I have to format the new drive and put the A/B folders and update file on it using the Linux tut in the video? And after doing so is there any other preparation I should have to do?
Does anybody know if it’s possible to transfer the hard drive from a broken Xbox One into a new one? I know that you can’t with the PS4 because it encrypts the drive so other devices can’t read it, but I can’t find anything saying whether or not the Xbox One does the same thing.
See this:
THREAD UPDATE JUNE 18, 2018:
This thread has been completely revamped. New information, new processes, and a new script.
Could use a little help :)…
I’ve done the clone fine for my Xbox One, to a new 1TB SSD.
However when i put it all back together and tried turning on the Xbox, it powers on for around 5 seconds or so (the light on the power adapter is white), then the xbox turns off and the power brick light goes orange. During this i don’t see anything on the screen.
I’ve tried: ''''
Connecting to a different monitor,
Different wall socket,
Different kettle lead,
Using the hairdryer thing mentioned over the fan/cpu side.
I’ve even gone as far as disconnecting everything from the motherboard, introducing components 1 by 1.
Any ideas what might be wrong?
Thanks in advance!
Got my parts yesterday and got the hard drive swapped out last night/this morning! I highly recommend using the video for disassembly so you can see exactly how to handle some of the more delicate parts of the process (like the ribbon cable on the front panel).
Also, one thing to note is that the HDD comes preformated for Xbox One; HOWEVER, you’ll still need a thumb drive with about 8GB of space and formatted to NTFS so you can install the Xbox OSU1 folder to it. The OSU1 folder is to perform an offline update once you finish all the manual labor in swapping the drive.
To get to this file, follow this link: https://support.xbox.com/en-US/xbox-one/...
Step 1: “I need to update my console offline.”
Step 2: “Original Xbox One.”
Steps 3, 4, & 5: “No”
Step 6: “Continue”
Step 7: “No”
Steps 8 & 9: (Complete the steps provided to download OSU1 and install it to the console)
Hope this helps and saves you a bit of legwork in getting your new HDD up and running! Cheers
Can confirm that this way works. My original HDD was toast, so I bought new Seagate 1TB HDD, put it right in without formatting it, installed OSU1 update and that was all. Xbox works and it took like 2 hours.
Thanks Benjamin :)
Jay -
Hi ! the link you prohave provided is not working….do you have a new link to the procedures ??
Roberto -
So I have had my XBox One S for a couple of years now and it stopped working. Could you tell me what the problem might be? So specifically the power button will light up and ding on like usual, then I hear the fan kick on, so it seems to start fine, but the power button will just blink and I can hear the HDD try to read but then it turns off about 10-15 seconds of blinking. I plugged the HDMI cable into the TV but it won’t detect the xbox is connected. I just bought a new SSD to replace the HDD but I’m a little worried that it might be a different issue. PLEASE HELP! Please tell me it’s not a motherboard issue :(.
I can’t put the top of the back Xbox one on, the front clips won’t clip, and ideas on how to do this w/o breaking it?
Hey, this guide was incredibly helpful in getting to my HDD, but I was hoping someone could help me out:
Recently my apartment was hit by a lightning strike and now my Xbox One turns off a few seconds after turning it on. I have game data that is user created content on the HDD that is extremely valuable to me that IS NOT synced on the live cloud. I really want to get this data backed up on the cloud or at least integrated onto another Xbox. If I connect this HDD into a different Xbox One internally, will the Xbox load this data as if it were my original Xbox and allow me to access everything on it?
I really would appreciate any advice on how to recover this data, cause I’m afraid of plugging into something and having it saved over permanently. Thanks in advanced!
For the steps where you slide a plastic opening tool through the back, I recommend you slide a flat, thin plastic triangle through instead.
I heard if you want replace the HDD buy SSD. The capacity of the new SSD you wanna use must be at lease same or bigger than the original HDD (mine is 500GB), otherwise Xbox won’t let you install the system. Is that true?
ssd are sata too, so this might be workin'. i've bought a kingston 0.48 tb ssd and i am just reading this article to know how install it.
to be honest i would rather buy a new xbox than do this - if you screw it up youre screwed and those hdds mostly die out of usage and so does the xbox, making upgrading it useless. - other old hardware inside the xbox will also wear out (thermal paste/cpu/vent etc) the hdd is only a precursor of this.
*and also : how to get the operating system on that new hdd ? - i assume this is also a different process ?
dear sir, my xbox one x hard drive stopped working, replaced it with the new one but its still startup error plz help.
thanks.
hello I am using HDD master 9 and OSU 1…I replaced my hardrive with a failed one that would not power on at all!…the new drive is installed successfully with these items and a boot dat file!….but for some reason my blue ray disc drive has stopped reading any disc’s I put inside please help me get the disc drive functioning again!
Keep getting a e100 0000706 80070004 Xbox one 1540 model. but when I put back the old drive I will finish why .but the original Xbox hd now beeping and don't even spin anyone more have same error and only the Seagate 1 tb mobile HDD st1000lm35 crystal disk info tells me drive is good I also seen that Xbox one is picky on hard drive like a YouTube guy out of 10 good drives the Xbox only liked 2 or 3 of them I there only what drive will it like best
Okay so recently I got a new xbox because my old motherboard bricked. If I replace the new xbox with my old hard drive, will there be issues? Without formatting, I mean.
Ciao a tutti la mia console Xbox One mi dà problema con hardware cosa posso fare?
Cambia l'hardware quello guasto allora.
Can i put a 4 tb hard drive in the xbox
No, Maximum is 2TB, anything higher than that wont work. You can go as high as you want over USB tho.
limit is 2048Gb, you cannot use the second half of the drive which remain unallocated.
Guten Tag zusammen ich habe eine XBOX one und wollte fragen ob ich eine externe Festplatte so dranklemmen kann mit Kabel
Here is an updated link for the Hard Drive Partitioning Script, which now also supports windows systems. So Linux installation is no longer needed: https://gbatemp.net/download/xbox-one-wi...
This worked brilliantly for me! Thanks for the great scripts, guides, and videos! Much appreciated!
In the United States the Magnuson-Moss Warranty Act of 1975 is a Federal Law that states that stickers and clauses are illegal. It says you can open your electronics without voiding the warranty, regardless of what language of that warranty says.
Dustin D'Amour - Ответить
Stickers are illegal!?
Brandon -
For anyone concerned, if you apply heat with a blow dryer or heat gun you can carefully remove the sticker without damaging it, making it impossible to know that the sticker was ever removed.
Kelton Stewart - Ответить
All the immature comments aside, thank you Dustin for sharing the information.
Wade - Ответить
xbox를 열기 위해서 이러한 위조방지 테이프를 자르거나 떼어내야 합니다. 하지만 걱정 마세요. 여러분이 무언가 직접적으로 망가트리지 않는한 ms는 보증을 취소하지 않습니다.
승대/SeungDae 정/Jeong - Ответить
