Введение
This guide showcases how the power supply can be replaced in case of a power issue on the Xbox One S All Digital Edition (Model 1681). Symptoms of a faulty power supply may be the Xbox turning on and off randomly or not turning on at all. Note that the entire console will have to be disassembled to properly replace the power supply without damaging other components. Disconnect all cables prior to disassembly.
Выберете то, что вам нужно
Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
Repeat on different points of the plastic enclosure until the bottom cover is removed.
Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
Apply pressure to peel off the sides of the casing.
Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
Gently lift the hard drive to free up some space around the power supply.
3 участников успешно повторили данное руководство.
2 Комментариев
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
