Введение
This guide is important because it is necessary to access certain components on the board that may need replacing.
  1. Flip the Xbox One S so that the bottom of the case is facing upward.
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Insert the plastic opening tool into the  gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
  3. Once all of the clips are opened, remove the bottom part of the case.
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Find all of the green screws on the metal case labeled F1 through F6. Take the T10 Torx screwdriver and remove the six 50 mm long screws.
    • Find all of the green screws on the metal case labeled F1 through F6.
    • Take the T10 Torx screwdriver and remove the six 50 mm long screws.
  5. The port cover is held in place with rivets. Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal. The port cover is held in place with rivets. Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal. The port cover is held in place with rivets. Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
    • The port cover is held in place with rivets. Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
    Do not remove the back panel from the metal housing by popping loose the “rivets” in Step 5 photo. Those are not rivets, they are melted post-end mounts in which the heads will break off and CAN NOT BE REPLACED by the do-it-yourself repairer (unless you want to try hot gluing the mounts back to the panel, but success is uncertain with this method). While doing my own tear-down following the photo examples, I thought the rear panel was meant to come off due to the photo of it laying next to the body in Step 7. This is inaccurate, and will most likely result in a loose fitting panel upon reassembly. The “rivets” no longer have a means to hold onto the metal body tray they came loose from. So you will have the panel relying on alignment back to the channel the tabs came out of in order to hold it to the back of your machine. Other than this issue, I was able to perform the tear-down without problem.
    Tad B - Ответить
  6. Gently separate the interior case from the white exterior case using the appropriate method. Gently separate the interior case from the white exterior case using the appropriate method.
    • Gently separate the interior case from the white exterior case using the appropriate method.
  7. To replace the hard drive, remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S. To replace the hard drive, remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
    • To replace the hard drive, remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
    The picture is incorrect. It is circling screw C5 on the left and not C4. But thanks for the help.
    John Carter - Ответить
  8. Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies). Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies). Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    Do not disconnect the connector in the second image! There are tiny prongs that bend easily and if bent just a tad bit they will break off. I had first hand experience with this and I ended up breaking my Xbox because I could not put that cable back on.
    Aaron Cooke - Ответить
    Do not remove the cable!!!! You can change while the cables are plugged. It took 2 hours trying to put mm precisely all the little pins because of the removal of the cables.
    Please update the post, I could easily end up as the Aaron, breaking the XBOX completly.
    Botond Kopacz - Ответить
  9. To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
  10. Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  11. To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • To replace the motherboard you must remove the three silver 10 mm T-10 Torx screws labelled "C1," "C2," and "C6."
    • Remove the four black 8 mm T-9 Torx screws lablelled "A1," "A2," "A3," and "A4."
  12. Locate the rectangular silver clamp on the opposite corner of the power block.
    • Locate the rectangular silver clamp on the opposite corner of the power block.
  13. Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • Grab the clamp with the tweezers. Pull the clamp upward, away from the silver casing. Jiggle it back and forth like a tooth if necessary.
    • It's okay to apply a little bit of force here to get the clamp off the silver casing. The metal is bendable and can be bent/clamped back on.
  14. Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
    • Now that the clamp is removed, gently lift the motherboard from its edges out from the metal casing. The motherboard should come out with ease.
Заключение
12 участников успешно повторили данное руководство.
Erik Ramazzini
Участник с: 26.04.2017
858 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 членов
Автор 33 руководств
Комментариев: 4
This guide is really missing alot between steps 13 and 14. There are two black panels that have to be removed(they’re in the teardown guide). One is on the front with with screws E1 ,E2, E3, E4. And theres another panel on the side with screws D1, D2, D3. Finally there are two more screws on the bottom that hold down the motherboard B1, and B2. Theres Also a black from in between the Fan and case that slides off too.
Nathan Stanley - Ответить
Yep, I was using this guide and realized that it is missing a few vital steps. Thank you Nathan.
Dave Miller -
If you have a multimeter could you please test the test points around the board and give me a list of a voltages?
Lilithe Lotor - Ответить
fantastic! only issues that are missing, are mentioned in the comments above. I´d like to include that most of the exterior hardcase clips are made to be HELD in place. Which is why it´s a nuisanse to remove. So, newcomers be careful with it. otherwise you´ll easily break it.
Mateus Cesar Loubach - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 17
За 7 дней: 165
За 30 дней: 715
За всё время: 12,628
