Xbox One S Optical Drive Replacement
Выберете то, что вам нужно
  1. Xbox One S Optical Drive Replacement, Case: шаг 1, изображение 1 из 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Optical Drive Replacement: шаг 2, изображение 1 из 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Optical Drive Replacement: шаг 3, изображение 1 из 1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Optical Drive Replacement: шаг 4, изображение 1 из 2 Xbox One S Optical Drive Replacement: шаг 4, изображение 2 из 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Optical Drive Replacement: шаг 5, изображение 1 из 2 Xbox One S Optical Drive Replacement: шаг 5, изображение 2 из 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield
  6. Xbox One S Optical Drive Replacement, Interior Case Top Panel: шаг 6, изображение 1 из 1
    • Flip the interior case so it is fan side upward.
  7. Xbox One S Optical Drive Replacement: шаг 7, изображение 1 из 1
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
  8. Xbox One S Optical Drive Replacement, Hard Drive Assembly: шаг 8, изображение 1 из 2 Xbox One S Optical Drive Replacement, Hard Drive Assembly: шаг 8, изображение 2 из 2
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
  9. Xbox One S Optical Drive Replacement: шаг 9, изображение 1 из 3 Xbox One S Optical Drive Replacement: шаг 9, изображение 2 из 3 Xbox One S Optical Drive Replacement: шаг 9, изображение 3 из 3
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
  10. Xbox One S Optical Drive Replacement, Optical Drive Assembly: шаг 10, изображение 1 из 1
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C5."
  11. Xbox One S Optical Drive Replacement: шаг 11, изображение 1 из 1
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
  12. Xbox One S Optical Drive Replacement, Optical Drive: шаг 12, изображение 1 из 1
    • Remove the black, flat Torx screw from the bottom of the optical drive.
  13. Xbox One S Optical Drive Replacement: шаг 13, изображение 1 из 2 Xbox One S Optical Drive Replacement: шаг 13, изображение 2 из 2
    • Detach the wires from the disc drive and slide the drive out.
    • If necessary, you can use plastic opening tools to pry the connectors off of the drive.
Заключение
20 участников успешно повторили данное руководство.
Andrew
Участник с: 04/26/17
4 604 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S22-G3, Livingston Spring 2017 Участник Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 членов
Автор 56 руководств
8 Комментариев
Why do you have to replace the motherboard when replacing the optical disc drive?
Alexander Anders - Ответить
because Microsoft puts a security code on the motherboard to pair the drive with the motherboard. so if they don’t match, all it will do is read DVDs and not play any games. Depending on the drive, sometimes you have to Unsolder and resolder the wires going to the motherboard. Other times, it can just be a series of clips for 2 cables and a plug.
If you learned basic soldering in High School, it isn’t too hard to solder.
Lawrence -
what do you need to solder, pics please…
Pete B - Ответить
Helped me get to the optical drive in order to disassemble it and remove a coin that was blocking the motor (gotta love toddlers). Thanks!
Russ Barker - Ответить
Is this what is to be done if the laser unit seems to be faulty?
Sharry Webb - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 24
За последние 7 дней: 119
За последние 30 дней: 542
За всё время: 29,841
