Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Insert the flat edge of a metal spudger in the seam between the adapter body and the plastic casing. Move the spudger into one of the corners.
Push down on the spudger to separate the casing from the adapter until you hear a click and the casing stays open on that side.
Do the same to the other side until the casing comes off.
Remove three 5.0 mm T5 Security Torx screws along the edges of the controller housing.
Remove two 8.0 mm T5 Security Torx screws near the top-center of the adapter.
With your fingers, carefully lift the adapter housing from the button panel.
Pull back on the controller USB connector with your finger to separate the main adapter circuit board from the rubber mold in the button panel.
With your fingers, partially peel back the rubber molding near the button you want to replace.
Using the straight, pointed end of a small pointed spudger, scrape off the glue between the plastic button and the rubber mold.
Grip the plastic tabs on either side of the button with tweezers.
Squeeze the tweezers to pop the button out the front face of the button panel.
