Xbox One Stereo Headset Speaker Replacement
Выберете то, что вам нужно
  1. Xbox One Stereo Headset Speaker Replacement, Speaker: шаг 1, изображение 1 из 1
    • Firmly grip the ear pad and the plastic back plate underneath. With your other hand, grip the back of the speaker casing.
    • Do not grip the back of the speaker by the headband. Twisting this connection will break the headphone off the headband.
    • With the ear pad facing you, push down on the back plate and turn counter-clockwise to unlock the prongs holding it in place. The back plate will only rotate about 1 cm.
  2. Xbox One Stereo Headset Speaker Replacement: шаг 2, изображение 1 из 1
    • Lift the back plate (with the ear pad attached) straight up from the speaker.
    • This should be very easy to do. If it doesn't come off easily, then the plate isn't fully rotated.
  3. Xbox One Stereo Headset Speaker Replacement: шаг 3, изображение 1 из 1
    • Remove three 7 mm Phillips #00 screws holding the speaker in place.
  4. Xbox One Stereo Headset Speaker Replacement: шаг 4, изображение 1 из 1
    • Carefully open the back casing, exposing the speaker wires.
  5. Xbox One Stereo Headset Speaker Replacement: шаг 5, изображение 1 из 1
    • Use wire cutters to cut the blue and black wires from the headset close to where they are spliced to the red and black wires from the speaker.
    • Splice the headset wires to the corresponding replacement speaker wires.
    • Black connects to black, red connects to blue.
    • Although soldering isn't necessary when splicing wires, doing so creates a more reliable connection.
Заключение
12 участников успешно повторили данное руководство.
Shannon Prouty
Участник с: 01/30/15
781 Репутация
1 руководство автора
Команда
Cal Poly, Team 17-37, Amido Winter 2015 Участник Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 членов
Автор 5 руководств
3 Комментариев
what part is using to hold the speaker in place that you can adjust to fit your head
Nicholas Ryver - Ответить
where can I buy the replacement speaker ?
Juan Carlos Sánchez Pulido - Ответить
Can some help me with fixing a earmuff detached from the head band but the wires are still attached
Harry Obrastsoff-Rutinsky - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 12,569
