Xbox One Wireless Controller Model 1708 Cover Plate Replacement
Выберете то, что вам нужно
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: шаг 1, изображение 1 из 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: шаг 1, изображение 2 из 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: шаг 2, изображение 1 из 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: шаг 2, изображение 2 из 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: шаг 3, изображение 1 из 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: шаг 4, изображение 1 из 2 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: шаг 4, изображение 2 из 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: шаг 5, изображение 1 из 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: шаг 6, изображение 1 из 3 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: шаг 6, изображение 2 из 3 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: шаг 6, изображение 3 из 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
Заключение
60 человек успешно провели ремонт по этому руководству.
Weston Gilmore
Участник с: 09/25/17
2 074 Репутация
1 руководство автора
Команда
Cal Poly, Team S18-G3, Forte Fall 2017 Участник Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 членов
Автор 37 руководств
4 Комментарии к руководству
i used a t8 and it worked
Rudy Bp - Ответить
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - Ответить
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - Ответить
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 25
За последние 7 дней: 163
За последние 30 дней: 539
За всё время: 33,239
