Введение
This guide details how to take off the outer plastic case of the Xbox One X. This could be useful for replacing the case itself if it is damaged. Removing the outer case is also necessary for replacing any of the interior components. Before starting, it is recommended that you make sure you have the right tools as well as a clean environment with plenty of room for organizing the components. Be aware that disassembling your Xbox could void your warranty, so you may want to read those terms and conditions in advance.
Инструменты
Запчасти
Детали не указаны.
Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
Using precision tweezers, remove the screw tab located on opposite side of the box.
Use a T9 Torx screwdriver to remove the 13mm screw revealed underneath the tab.
Orient the case so that the front of the Xbox (the side with the power button) is facing you.
Remove the top of the case by sliding the case towards you.
Bitte auch diesen Schritt überarbeiten. Es wird lediglich das Gehäuse für ca 2-4 Zentimeter nach hinten verschoben, dann sollte bereits das erste Hinterniss kommen, welches man ohne Gewalt nicht bewältigen kann. Hier muss das Gehäuse auf der Rechten Seite angehoben werden, dann lässt sich das Gehäuse ohne Probleme entfernen. Auch beim Zusammenbauen. Erst auf der Linkenseite bis zum ersten Plastik Haken (ca 2-4 Zentimeter vom Ende entfern) anlegen, danach auf der Rechten seite einklicken. Das Gehäuse kann auf der Rechten Seite auch etwas gedehnt werden, dabei geht nichts kaputt.
Please also revise this step. It is only the case for about 2-4 centimeters moved backwards, then should already come the first butt that you can not cope without violence. Here, the housing must be raised on the right side, then the housing can be removed without problems. Also when assembling. First put on the left side until the first plastic hook (about 2-4 centimeters from the end), then click on the right side. The case can also be slightly stretched on the right side, nothing breaks.
Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
I feel like someone wanted to use a T9 for everything, but these were T8.
You can use a T8 or T9 for this step. I was able to get all three screws with a T9 but there’s so little difference that both will work.
Remove the unscrewed panel from the side of the device by pulling it toward you.
Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
Unfortunately the manual is not correct here. Above the black slot is a white switch / pen, fold it over with your fingernail, so fold it over to the front. Then the cable can be easily removed without any problems and tweezers. GERMAN: Hier ist die Anleitung leider nicht korrekt. Oberhalb des schwarzen Steckplatzes befindet sich ein weißer Schalter/Stift, diesen mit dem Fingernagel umklappen, also praktisch zu der Vorderseite umklappen. Danach lässt sich das Kabel ohne Probleme und Pinzette einfach abziehen.
Thank you. Had no idea what the !&&* this guy was talking about with the “pull down" part. You flip it downward gently like a flap.
It is not necessary to remove the white flat cable. After removing the three gold screws from the board, go to the next steps and in step 9 remove the cover while hold the board against the cover to prevent stress on the white cable.
@Whole Witt, I second this. When you get to step 9 to remove the cover, just carefully remove the board, then remove the cover along with the board. You can leave the board in the cover.
On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
Remove both of these 7mm screws with a Torx T9 screwdriver.
Lift the detached plate off to the side.
These are actually T8. Be careful trying to use a T9.
Use a Torx T9 screwdriver to remove the six 47mm long screws, which attach the bottom side of the outer case.
These are all T10 on my Scorpio.
These are T10 on the Xbox One X MFR Date 22-OCT-2017. You could get away with T9 and would be careful.
My manufacture date is 15-JUN-18 and is not a Scorpio and is still T10. I would not recommend using a T9.
They are t-10 and t-8
Turn the Xbox over, so that the bottom of the case is on top.
Lift the bottom of the case off of the Xbox by pulling it up and toward you.
I had to slide it forward off of the disc drive a little bit before I could lift up.
When putting this cover back on, lay it flat and slide the case into it, slightly angling the front down so the plastic lugs on the BD-ROM fascia board slide into the slots in the cover You’ll have to push to the left slightly (with the cover flat side down and the front facing you) so as to depress the clip on the left-front side of the cover. You can check that the cover is on correctly by looking at the back of the cover and case and ensuring the screw holes on the cover line up with the case bezel.
6 участников успешно повторили данное руководство.
