Xbox One X Upper Plastic Case Replacement
Выберете то, что вам нужно
  1. Xbox One X Upper Plastic Case Replacement, Remove the sticker: шаг 1, изображение 1 из 2 Xbox One X Upper Plastic Case Replacement, Remove the sticker: шаг 1, изображение 2 из 2
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
  2. Xbox One X Upper Plastic Case Replacement, Remove the external screws: шаг 2, изображение 1 из 1
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
  3. Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: шаг 3, изображение 1 из 2 Xbox One X Upper Plastic Case Replacement, Slide the upper case horizontally: шаг 3, изображение 2 из 2
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
  4. Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: шаг 4, изображение 1 из 2 Xbox One X Upper Plastic Case Replacement, Lift the upper case off the lower case: шаг 4, изображение 2 из 2
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
  5. Xbox One X Upper Plastic Case Replacement: шаг 5, изображение 1 из 3 Xbox One X Upper Plastic Case Replacement: шаг 5, изображение 2 из 3 Xbox One X Upper Plastic Case Replacement: шаг 5, изображение 3 из 3
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
  6. Xbox One X Upper Plastic Case Replacement: шаг 6, изображение 1 из 2 Xbox One X Upper Plastic Case Replacement: шаг 6, изображение 2 из 2
    • Push the upper plastic case down and away from the console to remove it completely.
Заключение
11 участников успешно повторили данное руководство.
Kyle Smith
Участник с: 02/01/21
41 023 Репутация
Автор 123 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 106
За последние 30 дней: 302
За всё время: 10,296
