Введение
Follow this guide to replace the upper plastic case on your Xbox One X model 1787. You might do this to replace a broken upper case or install a custom version.
Turn off the console and unplug any cables before beginning this guide.
Выберете то, что вам нужно
Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
Rotate the console 90 degrees.
Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
Rotate the console 90 degrees so that the back is facing you.
Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
Swing the upper plastic case open to 75 degrees.
Push the upper plastic case down and away from the console to remove it completely.
11 участников успешно повторили данное руководство.
