Введение
Follow this guide to remove and replace the power button board on a Xbox Series S.
Выберете то, что вам нужно
Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
Lift straight up and remove the bottom panel from the plastic case.
Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
Remove the plastic case from the chassis.
Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
Use a spudger to pry and loosen the power button board.
Pull the power button board straight out to disconnect it from the chassis.
Еще один человек закончил это руководство.
Один комментарий
Can you tell me what on the power button board turns the console on?
