Введение
Use this guide to remove and replace a dead battery in the Xelio P900A-BK tablet.
Выберете то, что вам нужно
Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
