Введение
For problems pertaining to poor camera quality, please read this guide. This guide is for replacing the back-facing Camera on the Xgody D300. Please follow the steps carefully. By the end, your phone should be working as it normally should.
Выберете то, что вам нужно
Insert the pry tool into the seam and pry the back cover of the case along the seam until the cover is free of the case.
Using the Phillips #00 screwdriver, remove the screws that hold the protective housing to the smartphone; there should be 14 screws with a length of 3mm and one screw with a length of 6mm.
Three of the screws will not come loose from the protective housing and can be identified by a metal plate that is underneath them. In total there is 18.
Disconnect the camera by grabbing the connector with tweezers and firmly pull on the connector until it pops out.
