Введение
Use this guide to replace your Xiaomi Air 12 Motherboard.
Выберете то, что вам нужно
Orient the computer so the Xiaomi logo is at the bottom of the device.
Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
Detach the red wire from the tabs on the perimeter of the metal bracket.
Use a PH1 screwdriver to remove the five 2mm black screws.
Remove two silver 1mm JIS #00 screws.
Lift the battery up and pull out from the device.
Lift the silver connection cover next to the USB ports using the plastic opening tool and your hands.
Remove the four ribbon cables by lifting the connector up with the plastic opening tool and pulling the ribbon cable out.
Disconnect the gray and black wire connectors using the plastic opening tool to lift them up.
Lift the video cable on the connector using the plastic opening tool to disconnect it.
Gently lift the motherboard out by hand.
Where can I buy the motherboard?
подскажи, где купить материнку??
What is the motherboard name? Where can i buy it?
Any type number for the logic board / motherboard behind the cooling?
5 участников успешно повторили данное руководство.
11 Комментариев
Same here. Where to get motherboard to xiaomi mi 12?
Did yoiu get it?
zelenmix -
... I would like to replace but I can't find a motherboard anywhere ... can anyone help me, where to buy the board for best price?
Have you got it?
zelenmix -
Hi where i can buy mothreboard to replacrñe….?
Best regards
Hi, I am also searching for the motherboard, Did you find it?
Please guide me
Hello,
Are these motherboards that bad? Got one notebook here that is dead. Battery replacement did not help.
Roland
Hello, could you get the guide to change the keyboard?
I'd also like to replace the keyboard, have you found a good guide by chance (and a good replacement)?
Hello,
I have a problem on my Mi air 12 , specifically with the lcd cable port on the mother board. I want to replace it but i can’t seem to find where to buy the parts.
Pleas help me
Kind regards
L.
lanusjeleus - Ответить
