Введение
Use this guide to replace the speaker in your Xiaomi Air 12.
Выберете то, что вам нужно
Orient the computer so the Xiaomi logo is at the bottom of the device.
Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
Remove the white and black speaker wires from the black tabs by pulling upwards from the device.
Gently pull the speaker connector out from the connection point using your hand.
Remove the left speaker module by pulling the panel up from the device.
Repeat the same process for the right speaker module.
2 участников успешно повторили данное руководство.
6 Комментариев
have you found them? i need those too
Hello, i love this laptop and its been my companion for almost 3 years think the audio input jack got grounded because i heard a creaking sound when i inserted a metallic headset jack, the device was charging when it happened. Now the audio output from the audio jack port is like a minus one or somewhat instrumental. Any suggestions what to do?
