Xiaomi Mi 2 Screen Replacement Replacement
Выберете то, что вам нужно
  1. Xiaomi Mi 2 Screen Replacement Replacement, Remove screws and sim card: шаг 1, изображение 1 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Remove screws and sim card: шаг 1, изображение 2 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Remove screws and sim card: шаг 1, изображение 3 из 3
    • Remove the 2 Pentalobe screws.
    • Remove the sim card(s) from the phone.
  2. Xiaomi Mi 2 Screen Replacement Replacement, Remove adhesive: шаг 2, изображение 1 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Remove adhesive: шаг 2, изображение 2 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Remove adhesive: шаг 2, изображение 3 из 3
    • Insert the opening pick in the middle of the phone.
    • The 2nd image shows you where to put the opening pick in. You'll see that the screen will get loosen. There is lightly adhesive holding the screen.
    • Now take another opening pick and slide it around the whole screen.
    • Be careful not to put the opening pick in to far! This could damage the ribbon cable inside! Just slide it carefully around the screen.
  3. Xiaomi Mi 2 Screen Replacement Replacement, Loose the screen: шаг 3, изображение 1 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Loose the screen: шаг 3, изображение 2 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Loose the screen: шаг 3, изображение 3 из 3
    • The screen is now loose from the phone.
    • Do not remove the screen yet! It's still attached to the motherboard with the ribbon cable!
    • Just flip the screen carefully. The cable is short so please be careful! The ribbon cable can break easily. You could also hold the screen with your hand to be sure.
  4. Xiaomi Mi 2 Screen Replacement Replacement, Remove battery holder plate: шаг 4, изображение 1 из 2 Xiaomi Mi 2 Screen Replacement Replacement, Remove battery holder plate: шаг 4, изображение 2 из 2
    • Remove the 3 PH00 screws from the battery holder plate.
    • Now remove the battery holder plate with your tweezers carefully.
  5. Xiaomi Mi 2 Screen Replacement Replacement, Remove the screen: шаг 5, изображение 1 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Remove the screen: шаг 5, изображение 2 из 3 Xiaomi Mi 2 Screen Replacement Replacement, Remove the screen: шаг 5, изображение 3 из 3
    • Now you will see multiple cables attached to the motherboard.
    • Remove the battery ribbon cable first. This will prevent the phone from turning on accidentally by pressing the button. Please remove it straight out of it's socket with your finger nail or spudger (circled red).
    • Now remove the LCD ribbon cable straight out of it's socket with your finger nail or spudger (circled green).
  6. Xiaomi Mi 2 Screen Replacement Replacement, Screen removed: шаг 6, изображение 1 из 1
    • You successfully removed the screen now!
Заключение
Don’t forget: It’s possible that you need to transfer the backplate and/or bracket and/or small parts! How to transfer those items are NOT included in this guide.
Note: New adhesive is required to attach the bracket/earpiece/earpiece dust filter again if needed.
5 участников успешно повторили данное руководство.
koppie007
Участник с: 08/22/13
11 662 Репутация
Автор 9 руководств
Команда
Protectors Of The Game Systems Участник Protectors Of The Game Systems
Community
4 членов
Автор 24 руководств
4 Комментариев
Hi!
Depends on how your new screen came in. Some of them do not have the frame where it fits in, so you need to transfer the frame from the old one.
It’s glued, so you need to heat it to detach the screen from the frame and need to glue it to the new screen. Then follow the guide in reverse order to reassemble it.
Note: The silver plate is attached to the frame, be carefull for it and also for the small parts on it.
koppie007 - Ответить
This isn't a guide for the Xiaomi Mi 2/2S, please fix the title.
TipzTeam - Ответить
Hi! This is regarding the Xiaomi Mi 2 only. Not sure if it’s applicable for the 2S. This device used in this guide is Mi 2.
koppie007 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 33
За всё время: 1,853
