Xiaomi Mi 4 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Xiaomi Mi 4 Front Facing Camera Replacement, Rear Case/Midframe: шаг 1, изображение 1 из 3 Xiaomi Mi 4 Front Facing Camera Replacement, Rear Case/Midframe: шаг 1, изображение 2 из 3 Xiaomi Mi 4 Front Facing Camera Replacement, Rear Case/Midframe: шаг 1, изображение 3 из 3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Front Facing Camera Replacement: шаг 2, изображение 1 из 3 Xiaomi Mi 4 Front Facing Camera Replacement: шаг 2, изображение 2 из 3 Xiaomi Mi 4 Front Facing Camera Replacement: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Metal Spudger
    $2.99
    Купить
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Front Facing Camera Replacement: шаг 3, изображение 1 из 3 Xiaomi Mi 4 Front Facing Camera Replacement: шаг 3, изображение 2 из 3 Xiaomi Mi 4 Front Facing Camera Replacement: шаг 3, изображение 3 из 3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Front Facing Camera Replacement, Battery: шаг 4, изображение 1 из 3 Xiaomi Mi 4 Front Facing Camera Replacement, Battery: шаг 4, изображение 2 из 3 Xiaomi Mi 4 Front Facing Camera Replacement, Battery: шаг 4, изображение 3 из 3
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Front Facing Camera Replacement: шаг 5, изображение 1 из 2 Xiaomi Mi 4 Front Facing Camera Replacement: шаг 5, изображение 2 из 2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
  6. Xiaomi Mi 4 Front Facing Camera Replacement, Motherboard: шаг 6, изображение 1 из 1
    • With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
    • Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
  7. Xiaomi Mi 4 Front Facing Camera Replacement: шаг 7, изображение 1 из 2 Xiaomi Mi 4 Front Facing Camera Replacement: шаг 7, изображение 2 из 2
    • Wedge the plastic opening tool, between the motherboard and the inner region of the phone in the slot atop the motherboard.
  8. Xiaomi Mi 4 Front Facing Camera Replacement, Front Facing Camera: шаг 8, изображение 1 из 3 Xiaomi Mi 4 Front Facing Camera Replacement, Front Facing Camera: шаг 8, изображение 2 из 3 Xiaomi Mi 4 Front Facing Camera Replacement, Front Facing Camera: шаг 8, изображение 3 из 3
    • With the motherboard detached from the phone, locate the front camera in the upper left-hand corner.
    • Use a pair of tweezers to disconnect the front-facing camera by popping the cable off of the motherboard connector.
Заключение
10 участников успешно повторили данное руководство.
William Pendeergraft
Участник с: 09/08/15
2 407 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 15-6, Blackwell Fall 2015 Участник USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
2 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 5,800
