Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
Инструмент, используемый на этом этапе:Metal Spudger$2.99-
Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
Using the second spudger, slowly work your way around the perimeter of the device
As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
9 участников успешно повторили данное руководство.
