Введение
Use this guide to remove the rear-facing camera from your Xiaomi Mi Pad.
Выберете то, что вам нужно
Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
Use a plastic opening tool to disconnect the rear-facing camera from the motherboard.
2 человек успешно провели ремонт по этому руководству.
