Xiaomi Redmi 2 Motherboard Replacement
Выберете то, что вам нужно
  1. Xiaomi Redmi 2 Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 2 Xiaomi Redmi 2 Motherboard Replacement, Motherboard: шаг 1, изображение 2 из 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
    That's unnecessary. The cover itself has a small notch on it to remove it to the left
    Mad Max - Ответить
  2. Xiaomi Redmi 2 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Motherboard Replacement: шаг 6, изображение 1 из 2 Xiaomi Redmi 2 Motherboard Replacement: шаг 6, изображение 2 из 2
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Motherboard Replacement: шаг 7, изображение 1 из 2 Xiaomi Redmi 2 Motherboard Replacement: шаг 7, изображение 2 из 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
    I broke the connector of this flat cable, which with a replacement part without having to change the entire mother board? Another doubt, this flat cable is responsible for which function in the cell?
    lucaslgf2 - Ответить
    pull up the black plastic part of this conector to free the ribbon before remove! this step is missing!!!!
    Rodrigo Cunha - Ответить
    Thanks Rodrigo, saved me!
    Rodrigo -
  8. Xiaomi Redmi 2 Motherboard Replacement: шаг 8, изображение 1 из 2 Xiaomi Redmi 2 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Motherboard Replacement: шаг 9, изображение 1 из 2 Xiaomi Redmi 2 Motherboard Replacement: шаг 9, изображение 2 из 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Motherboard Replacement: шаг 10, изображение 1 из 2 Xiaomi Redmi 2 Motherboard Replacement: шаг 10, изображение 2 из 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Motherboard Replacement: шаг 11, изображение 1 из 1
    • Lift the motherboard out of the front cover and set aside.
Заключение
46 участников успешно повторили данное руководство.
Alicia Brenner
Участник с: 10/01/15
3 539 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 1-3, Leahy Fall 2015 Участник USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 членов
Автор 5 руководств
17 Комментариев
this is very helpful
Ana - Ответить
hi brother mi phone was water damaged .it was not wrking i mean phone gets on but no display. phone gets ring and i can lift call and speak. when i connect to laptop i can access files in it. its get charging on connecting to charger
can u suggest me wat to do
please
asreefbashak - Ответить
may be LCD is damage. can fix it at 82877181 contact Peter for checking.
netman91 -
Hi bro I'm having redmi 2 mobile and it has a problem it is not taking any os it's having a compliant of not receiving os .....
There is any solution for that
Please give me reply bro any suggestions
jhon Carter - Ответить
Can i know the name of the motherboard used for redmi 2 prime 16GB,please tell me the name bro
Jakka Akhilesh - Ответить
how and where to buy motherboard for redmi2
DHANANJAY KALKOTE - Ответить
i want new mothe board redmi
ASHOK KUMAR - Ответить
i want redmi 2 prime mother board
How to buy redmi prime 2 mother bord
ANYTHING ANYBODY - Ответить
hey my Redmi 2 is not working, what can I do? it started to make turn off it self time by time and after it turn off completly, if I make to turn it it on not working, it makes vibration only without turn on, what can I do?? please help me because am just seeking a help
NIYIGENA Moses - Ответить
Sir, my phone (Redmi 2 prime) doesn't starts. One day it got off on 0% charge. I put it on charge but from the next day it was not opening. What to do?
Sagarnil Mukherjee - Ответить
My phones mother bord is damaged I needed it
mohan gowda - Ответить
My phone is mother board damage I need it
Rishikesh Meena - Ответить
Hello, i want ask for u, my handpone redmi 2 lte can’t on..why? What is problem?
sazuwan saz - Ответить
Great! This phone is very easy to disassembly!
Serg - Ответить
السلام عليكم
لدي جوال شاومي s2
منفذالشاحن خربان
Omar Halawane - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 34,981
