Введение
Use this guide to remove the PCB circuit board in your Xiaomi Redmi 2 for repair or replacement.
Запчасти
Детали не указаны.
  1. Xiaomi Redmi 2 PCB Circuit Board Replacement, Motherboard: step 1, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement, Motherboard: step 1, image 2 of 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 2, image 1 of 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 3, image 1 of 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 4, image 1 of 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 5, image 1 of 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 6, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 6, image 2 of 2
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 7, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 7, image 2 of 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 8, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 8, image 2 of 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 9, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 9, image 2 of 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 10, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 10, image 2 of 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 11, image 1 of 1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 PCB Circuit Board Replacement, PCB Circuit Board: step 12, image 1 of 1
    • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
  13. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 13, image 1 of 1
    • Using the tweezers, lift the antenna connector from the PCB circuit board.
  14. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 14, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 14, image 2 of 2
    • Do not remove the PCB circuit board at this time.
    • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
  15. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 15, image 1 of 1
    • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
  16. Xiaomi Redmi 2 PCB Circuit Board Replacement: step 16, image 1 of 2 Xiaomi Redmi 2 PCB Circuit Board Replacement: step 16, image 2 of 2
    • Carefully lift the PCB circuit board from the screen assembly and set aside.
    • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
Заключение
14 участников успешно повторили данное руководство.
Alicia Brenner
Участник с: 01.10.2015
3 509 Репутация
Автор 5 руководств
USF Tampa, Team 1-3, Leahy Fall 2015 Участник USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 членов
Автор 5 руководств
3 Comments
my phone is head phone signal
Momo Bachaspatimayum - Ответить
Battery terminal shouting help
Adil - Ответить
I want purches PCB Circuit not available in Akola service center
narendra thokal - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 20,509
