Введение
The Xiaomi Redmi Note 3 is an easy to open phone that has an easy to remove battery. Almost reaching repairablity perfection, the phone falls short at 8 out of 10 due to its difficult to replace display.
Запчасти
Детали не указаны.
  1. Xiaomi Redmi Note 3 Repairability Assessment, Xiaomi Redmi Note 3 Repairability Assessment: step 1, image 1 of 3 Xiaomi Redmi Note 3 Repairability Assessment, Xiaomi Redmi Note 3 Repairability Assessment: step 1, image 2 of 3 Xiaomi Redmi Note 3 Repairability Assessment, Xiaomi Redmi Note 3 Repairability Assessment: step 1, image 3 of 3
    • Exterior reference photos.
  2. Xiaomi Redmi Note 3 Repairability Assessment: step 2, image 1 of 2 Xiaomi Redmi Note 3 Repairability Assessment: step 2, image 2 of 2
    • There are no exterior screws. The top and bottom panels of the rear case are made of plastic, but cannot be separated from the rest of the case.
    • Prying the body of the phone out of the rear case is fairly straight-forward, the plastic clips holding it are flexible enough to bend without breaking, and are not too strong.
    • Fingerprint sensor cable connects the rear case to the interior of the phone, but is long enough that you can safely disconnect it without damaging it.
  3. Xiaomi Redmi Note 3 Repairability Assessment: step 3, image 1 of 2 Xiaomi Redmi Note 3 Repairability Assessment: step 3, image 2 of 2
    • Fingerprint sensor is the only component left in the rear case.
    • Fairly easy to remove by pushing through the back of the case.
  4. Xiaomi Redmi Note 3 Repairability Assessment: step 4, image 1 of 2 Xiaomi Redmi Note 3 Repairability Assessment: step 4, image 2 of 2
    • Battery pull strips are awesome for easy battery removal.
    • Battery removed.
  5. Xiaomi Redmi Note 3 Repairability Assessment: step 5, image 1 of 3 Xiaomi Redmi Note 3 Repairability Assessment: step 5, image 2 of 3 Xiaomi Redmi Note 3 Repairability Assessment: step 5, image 3 of 3
    • First layer of removable components includes: loudspeaker assembly, antenna, buttons, vibrator bracket, front- and rear-facing cameras.
    • Next out: interconnect cable and antenna interconnect.
    • Next out, daughterboard with charging port.
  6. Xiaomi Redmi Note 3 Repairability Assessment: step 6, image 1 of 2 Xiaomi Redmi Note 3 Repairability Assessment: step 6, image 2 of 2
    • Motherboard removal, the only component removed from the motherboard is a rubber duct for the microphone.
    • The main board is pretty minimal, but the headphone jack is soldered on, making jack replacements expensive.
    • Final components off of the display assembly are the vibrator and earpiece speaker.
    • The fused, midframe-mounted display assembly is last out, making fixing a broken screen a more expensive and time consuming repair.
  7. Xiaomi Redmi Note 3 Repairability Assessment: step 7, image 1 of 2 Xiaomi Redmi Note 3 Repairability Assessment: step 7, image 2 of 2
    • The Xiaomi Redmi Note 3 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
    • Despite no external screws, the rear case is fairly easy to remove.
    • Battery is easy to access and remove.
    • Modular design with charging port on its own daughterboard means many components can be independently replaced.
    • Display assembly is a single fused component, that requires disassembling the entire phone to replace.
    • Manufacturer does not provide user-accessible repair documentation.
Финишная черта
81 участников успешно повторили данное руководство.
Andrew Optimus Goldheart
Участник с: 17.10.2009
490 052 Репутация
Автор 410 руководств
iFixit Участник iFixit
Community
146 членов
Автор 16 130 руководств
23 Comments
Thanks for this guide. Almost Identical to a Galaxy Note 3 screen replacement. A lot easier than I though it would be.
Clems - Ответить
Thank you so much for posting this teardown!
My Redmi Note 3 Pro developed a charging problem, and this post gave me the basics I needed to replace the usb daughterboard.
The phone was acting weird... When plugged in to a charger, the led indicator did not light up. I tried 7 different chargers and cables including 0.5, 1 and 2amp units. What was strange was that when it was plugged into a dual or quad port charger, any other devices stopped charging immediately. Those with led indicators switched off when it was plugged in.
I hoped it was a short circuit or fault in the usb port, which I learned here was replaceable. So I ordered the part on eBay and replaced it myself at home. All up it cost me $11 to fix my phone, and it is now working as normal again.
I'd like to add that one of the screws holding the speaker assembly is hidden under a tiny sticker, and the assembly and usb daughterboard are both also held in place by glue or double sided tape. Lift carefully and they come off quite easily.
Carl Cook - Ответить
Where did you buy the usb charging port board (daughterboard)? I have the exact same problem, except the turning off of charging on devices only happens when I bend the charger down slightly. Do you have any problems with mobile data/ calling/wifi and or bluetooth?
Lindsay Tang -
I have a problem with my xiaomi redmi 3 pro, first, my wifi and my bluetooth can't activated, then now my device can't read my SIM card.. What should i do?:(
Vincent Theo - Ответить
Hey,I was replacing my charging port and forgot to remove the sd card/sim card slot before opening the case.
I didnt open it all the way,but now my sd card wont load and not just the one I had in when it happened,but any I put in.
What can I do?
please respond
blackdevilonline - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 26
За последние 30 дней: 140
За всё время: 66,928
