Введение
If you are experiencing poor sound quality or no sound, the speakers may be faulty. This guide will explain how to replace the Luna's speakers.
Выберете то, что вам нужно
Flip the device over so that the batteries are closest to you.
Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
Push the battery against the spring and lift it out of the casing.
Repeat with the other battery.
Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
Gently tilt the lid back 45 degrees so that the inside is exposed.
Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Unscrew the three 7 mm black screws using the Philips #1 screwdriver on the back end of the left and right circuit board.
Use a plastic opening tool to pry the black connections away from the top casing.
Turn the circuit boards over. Remove the two connections on the left side by pulling on the tabs.
