Введение
Through normal wear and tear or rough handling, saxophone corks can become damaged, rendering the instrument useless or operating at diminished quality. This guide will replace a Yamaha YAS-23 alto saxophone cork; however, the size for all alto saxophone neck-pieces is standard, so this repair is applicable to all alto saxophone neck-piece cork repairs.
For optimal performance, saxophones require a well fitting cork. Without this, tone quality will be sacrificed, or the saxophone will cease to function.
Выберете то, что вам нужно
Locate the screw on the side of the neck-piece, connecting the octave key to the neck-piece.
Use a small, 2.5 mm flat head screwdriver to remove the screw.
Use the utility blade to scrape off the cork.
Start at the base of the cork on the neck-piece with the utility blade at a 10 to 20 degree angle.
In a controlled motion, drag the utility blade along the neck-piece, removing cork along the way.
Repeat until all of the cork is removed.
Apply masking tape where there is no glue on the neck-piece to prevent damage to the finish.
Remove glue and resin by rotating the neck-piece against the 220 grit sand paper.
Repeat until all glue is gone.
Инструмент, используемый на этом этапе:Microfiber Cleaning Cloths$3.99
With a damp microfiber cleaning cloth, wipe off any dust and glue particles.
Place the Valentino neck cork flush with the entrance of the neck-piece.
Mark a line where the Valentino neck cork meets the masking tape.
Cut along the line.
Wrap Valentino neck cork around the neck-piece.
Make mark where the Valentino neck cork overlaps.
Remove the adhesive covering on the back of the Valentino neck cork.
Wrap the Valentino neck cork around the top of neck-piece.
Sand the seam of the Valentino neck cork until it is even with the rest of the Valentino neck cork.
Re-insert the screw.
Tighten the screw with a small, 2.5 mm flat head screwdriver.
The replacement is complete.
Еще один человек закончил это руководство.
Один комментарий
I’m usually here for computer guides, I couldn’t believe a sax guide was here! Was overjoyed! Can someone make a Alto Sax full pad replacement guide? I know it’s a big ask! But I have a YAS-23 and it needs all new pads, getting it serviced by a pro is between $700-$850!! But buying pads yourself is as low as $50 or on the high end $200. This seems like a tutorial the world needs to have! Thank you to anyone that even took the time to read this.
