Введение
Open the console and replacing the faders, step by step. This job need soldering skills an couple of hour.
Выберете то, что вам нужно
Remove 5 screws:
Three screws for the lower part
Two screws for the upper part
Use a #4 Phillips screwdriver.
Remove sub-d connector from bargraph.
Remove 4 screws (2shorts/2 long) from metal bracket and mixing desk.
Remove 15 screws:
Remove 1 smaller screw
remove Phillip screw #2
Attention: these are self-tapping screws => risk of creating chips when screwing.
remove 16 + 1 fader with fingers or a with a plastic card.
remove 4 screws at the back.
remove 4 screws at the front (bad pic here).
remove carrefully from the side the 2 withe connectors.
remove carrefully 2 cables from the power unit, unlock first the connector.
open carefully the console from back to front by graping the sides.
open connectors and remove 5 cables.
you can now remove the upper part of the console.
Cut the plastic clamps. Their are 4 clamps in the corners and 1 clamp holding flat cable in place.
Unscrew the 10 screws with a Phillips #2 screwdriver.
remove solder from 4 metal bracket that are fixed to the PCB from the cover.
remove solder with a pump from 6 pin of the fader.
remove solder from the 2 pin of the motor of the fader.
Replace transistors by new ones.
2SB1181.
2SD1733.
they are hard to find as the are being obsolete.
An idea from web forum from a Yamaha Technician that propose to add 4X 1N4148 diode by fader to protect the transistor. as free wheel.
add diode between base and collector as show here.
To reassemble your device follow the following instructions in reverse order.
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
