Введение
Use this guide to install a replacement keyboard display.
Выберете то, что вам нужно
Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
Locate the main circuit board in the middle of the detached face plate.
Use a plastic opening tool or spudger to carefully pry up the beige ribbon connectors and remove the wires from them.
Use a slightly upward force as parallel to the ground as possible.
Be sure to unplug the smaller ribbon that connects to a different circuit board.
Move the ribbons out of the way, and remove the eight 10mm screws in the middle that hold the circuit board down.
Remove the two 12mm screws in the corner of the circuit board.
2 участников успешно повторили данное руководство.
