Введение
Learn to remove and replace a broken key for your keyboard with this guide. The process is fairly simple and mostly requires the removal of screws.
Выберете то, что вам нужно
Locate the six batteries and remove them from the battery cavity.
Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
Remove the block of keys that holds the key you wish to install.
To do this, apply a small force away from the top of the keys and slightly toward the floor.
If done correctly, the block of keys will come to a slight downward angle.
Press the tab on the back side of the block of keys out and detach the black keys.
Remove the individual white key(s) or the black key set(s) that require replacement.
7 участников успешно повторили данное руководство.
3 Комментариев
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Great article. Thank you so much.
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
