Введение
My device was water damaged so I decided to take it apart! You will see signs of corrosion on the motherboard and electronics closeup images.
Remove 2 Phillips head screws. There is one on each side of the device
Remove buttons and aperture/shutter pieces
They should just fall out. If not, they can be removed with your fingers
Pull the clear plastic out and away to the left
Pull up at an angle
Slide the circuit board back so that it is not under the plastic lip
Slowly peel the battery and circuit board away from the plastic housing
Grip the plastic case and use your thumb to remove the height adjustment module
It should slide out all the way
There are two ball bearings that make the height adjustment module work and lock into position.
Use a spudger to carefully remove the screen
It is held down with adhesive
For reassembly, place the slots on the small shutter pieces into the circular holder
4 участников успешно повторили данное руководство.
4 Комментариев
I somehow managed to get a single hair under the casing and over the screen on my Yocan Uni Pro. With the help of this guide, I was able to disassemble, clean, and re-assemble my vape quickly and easily - I'm especially grateful for the pictures showing how to disassemble/reassemble the shutter pieces. Thank you so much for this awesome guide!
