Введение
If you are having issues landing your Yuneece Breeze 4K, it is probably due to a leg being broken or chipped. This guide shows you how to safety remove one of the legs and replace it with a new one. We have also provided a link for you that will show you where new replacement legs can be purchased.
Выберете то, что вам нужно
Turn the drone over so the propellers are facing down. Pull the leg up so the leg is pointed up towards the ceiling.
Firmly grasp the leg so it is snug between your fingers.
As you are grasping the leg, turn the leg counter clockwise about 80-90 degrees and pull up. This should take the leg out of its socket.
Pull up so the leg is out of it's socket. Now you can put in the replacement leg.
Еще один человек закончил это руководство.
