Введение
Is your drone not functioning the way you want it to? Consider using this guide to replace the motherboard in your drone.
Выберете то, что вам нужно
Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
Flip over the drone so that the propellers are facing down and the camera is facing up.
Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
Remove the 4 rubber plugs that hold the drone and its internal parts together.
These plugs can be located in each corner of the drone, and are white.
The rest of the wires that are still connected can be unplugged.
Using a pair of tweezers they can be unplugged.
The battery connector has two wires connected to a plug in with two little screws.
Unscrew the two screws and pull it apart using a small tweezers.
Flip over the frame and mother board and unscrew the mother board.
There are four screws on each corner of the mother board.
After the screws are out, the motherboard can be pulled out softly with hands.
Remove the motherboard from the device.
5 участников успешно повторили данное руководство.
