Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If you own a Yuneec ST10 Plus, there is a chance your battery will stop holding its charging capacity over time. The main causes of this issue are battery overheating, and the end of your battery charge/discharge cycles. Follow this step-by-step guide on how to replace your battery. No tools required and a quick replacement.
  1. Flip the controller upside down to access the battery compartment.
    • Flip the controller upside down to access the battery compartment.
    • Grab the compartment door and pull down.
  2. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
    • Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
  4. To disconnect the battery from the remote, grab the red and black connectors. Pull gently on connectors until they disconnect. Pull gently on connectors until they disconnect.
    • To disconnect the battery from the remote, grab the red and black connectors.
    • Pull gently on connectors until they disconnect.
Заключение
2 участников успешно повторили данное руководство.
Justin Vega
Участник с: 15.01.2020
207 Репутация
1 руководство автора
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 50
