Yuneec Typhoon H Slip Ring Yaw Motor Replacement
Выберете то, что вам нужно
  1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement, Slip Ring Yaw Motor: шаг 1, изображение 1 из 1
    • Remove the Motor Battery Component from the Drone.
  2. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 2, изображение 1 из 2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 2, изображение 2 из 2
    • Prop the top cover of the motor piece off the Motor Battery Component. Using Phillips #00 screwdriver, unscrew the three screws (their lengths are 5.9 mm) that are in this top cover piece. This will remove the battery from the top piece.
  3. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 3, изображение 1 из 1
    • Grabbing the Motor Piece, remove the bottom cap of this motor piece. The cap should pop right off.
  4. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 4, изображение 1 из 1
    • Using the Philips #000 screwdriver, unscrew the two 5.9 mm screws and remove the retaining clip on top of the motor piece.
  5. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 5, изображение 1 из 1
    • Using the Phillips #1 screwdriver, remove the four 6.3 mm motor mount screws on top of the motor piece.
  6. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 6, изображение 1 из 1
    • Once these screws are removed, pop off the top of the motor piece.
  7. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 7, изображение 1 из 2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 7, изображение 2 из 2
    • Using the Phillips #000 screwdriver, remove the two 4.9 mm screws on the side of the plastic cover holding the wires together.
    • Once these screws are removed, press down on this plastic cover to reveal the wires. Pull the locking tabs that are on the end of this piece to completely remove this plastic cover.
  8. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 8, изображение 1 из 2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 8, изображение 2 из 2
    • Pull out the white wire connecter that is currently in the wire assembly.
  9. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 9, изображение 1 из 1
    • Remove the white wire connector cap using the tweezers. This is for the wires that are currently in the motor piece. Do take note of the orientation and order of the wires.
  10. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 10, изображение 1 из 2 Yuneec Typhoon H Slip Ring Yaw Motor Replacement: шаг 10, изображение 2 из 2
    • Removed the damaged slip ring motor by guiding the wires through the opening in the motor piece. Use a pair of pliers to make sure the wires are pushed through the opening in the center of the motor piece.
Заключение
To reassemble your device, follow these instructions in reverse order (This process is in the guide steps for reference).
3 участников успешно повторили данное руководство.
Davis Ross
Участник с: 04/16/18
321 Репутация
1 руководство автора
Команда
Cal Poly, Team S22-G3, Maness Spring 2018 Участник Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 членов
Автор 5 руководств
2 Комментариев
Ive done all the above but digging out the epoxy it took almost all wire with it i couldve solderd to so what to do now its the white wire by the way the camera still stabalises and points straight just cant manually control
donkymeet - Ответить
The White or Green wire is most likely not making connection
YuneecSkins.com -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,309
