Введение
This guide is created to explain how to replace the LB and RB buttons on your ZD-N208 Plus Wireless Controller. Bumpers can be found on eBay for $3.00.
Выберете то, что вам нужно
Remove the seven 12mm JIS #00 screws that hold the back panel in place.
Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
Remove the electrical connector attaching each rumble motor to the controller.
Lift up on the circular section of the rumble to remove it from the controller.
Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
The LB/RB buttons can be easily pulled from the top of the controller.
Еще один человек закончил это руководство.
