Введение
Use this guide to replace your perishing battery.
After successfully removing the battery, and putting a new battery in, your device should now power on properly.
Remove the back cover using the notch at the bottom of the device.
Pull the back cover from the front panel gently to remove it.
Remove the battery by the notch in the back plate.
Once you have removed the battery replace it with the new one.
Carefully insert the new battery with the connectors aligned correctly.
Gently push down on the battery until it clicks into place.
4 участников успешно повторили данное руководство.
