Введение
Be cautious when replacing the audio jack-- it is fragile and breaks easily. Tweezers are the optimal tool to use in order to remove and replace the audio jack.
Запчасти
Никакие детали не требуются.
  1. Remove the back cover of the phone to expose the phone's mid-frame.
    • Remove the back cover of the phone to expose the phone's mid-frame.
  2. Pry the battery up and out of the phone.
    • Pry the battery up and out of the phone.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  5. Wedge the flat end of the spudger between the mid frame and the digitizer. Wedge the flat end of the spudger between the mid frame and the digitizer. Wedge the flat end of the spudger between the mid frame and the digitizer.
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  6. Gently pry the mid frame away from the rest of the phone to expose the motherboard. Gently pry the mid frame away from the rest of the phone to expose the motherboard.
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  7. Locate the audio jack at the upper right hand corner of the device. Use the metal spudger to pry the motherboard away from the device. Use the metal spudger to unfasten the audio jack and pull it away from the motherboard.
    • Locate the audio jack at the upper right hand corner of the device.
    • Use the metal spudger to pry the motherboard away from the device.
    • Use the metal spudger to unfasten the audio jack and pull it away from the motherboard.
Заключение
3 участников успешно повторили данное руководство.
Jennifer DeMeo
Участник с: 07.10.2014
960 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 1-2, Leahy Fall 2014 Member of USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 6
За 30 дней: 19
За всё время: 2,250
