Введение
This guide goes through how to safely disassemble the ZTE Blade Spark and replace the battery. This device contains electrical components, and the repair should be preformed in a dry environment. Replacing your battery is easy and a great way to give your device a fresh start.
Выберете то, что вам нужно
Apply heat evenly on the back cover using the iOpener to soften the adhesive.
Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
Gently remove the SIM card tray.
To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
After removing the inner white panel you should see a black panel. Use a Phillips #00 screwdriver to remove the six 4.0 mm screws.
