ZTE Blade Spark Rear-Facing Camera
  1. ZTE Blade Spark Rear-Facing Camera, ZTE Blade Spark Rear-Facing Camera: шаг 1, изображение 1 из 1
    • First, apply heat evenly on the back cover using a heat sack to soften the adhesive.
  2. ZTE Blade Spark Rear-Facing Camera: шаг 2, изображение 1 из 1
    • Now, carefully remove the back cover.
  3. ZTE Blade Spark Rear-Facing Camera: шаг 3, изображение 1 из 1
    • Once opened, Locate and remove all exposed screws using a Phillips-Head screwdriver and set them aside.
  4. ZTE Blade Spark Rear-Facing Camera: шаг 4, изображение 1 из 1
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Rear-Facing Camera: шаг 5, изображение 1 из 1
    • After removing the white plastic panel, you should see a black metal battery cover.
    • To remove the metal battery cover, remove the screws from the panel using a Phillips screwdriver if you have not yet done so.
  6. ZTE Blade Spark Rear-Facing Camera: шаг 6, изображение 1 из 1
    • Then, simple lift to remove the metal battery cover.
  7. ZTE Blade Spark Rear-Facing Camera: шаг 7, изображение 1 из 1
    • You have reached the Fingerprint Scanner, the device Battery, and Front Facing Camera.
  8. ZTE Blade Spark Rear-Facing Camera: шаг 8, изображение 1 из 3 ZTE Blade Spark Rear-Facing Camera: шаг 8, изображение 2 из 3 ZTE Blade Spark Rear-Facing Camera: шаг 8, изображение 3 из 3
    • Proceeding with disassembly, next up is the top chipset which the Rear Facing Camera is attached to.
    • To detach the chipset and reach the Rear Camera, locate and disconnect five power connectors surrounding the top chipset (as shown in images).
  9. ZTE Blade Spark Rear-Facing Camera: шаг 9, изображение 1 из 1
    • Once you have the power connectors disconnected from the top chipset, use a Phillips screwdriver to remove the final screw located at the very top of the chipset (as shown in image).
  10. ZTE Blade Spark Rear-Facing Camera: шаг 10, изображение 1 из 1
    • Then, simply lift chipset from top and detach from the device frame.
  11. ZTE Blade Spark Rear-Facing Camera: шаг 11, изображение 1 из 1
    • You have now reached the final replacement component of the device, the Rear Facing Camera!
    • For step-by-step instructions on replacing any of the device components covered throughout the disassembly process, check out our ZTE Blade Spark Replacement guides.
Заключение
2 участников успешно повторили данное руководство.
Hung Vu
Участник с: 01/24/18
632 Репутация
1 руководство автора
Команда
Gateway, Team S1-G6, Johnson Spring 2018 Участник Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 22
За всё время: 2,231
