Введение
An old battery can lead to increasingly shorter times between charges and reduced phone performance.
Be sure to discharge your battery as much as possible before you attempt this repair. LiPo batteries can catch fire and cause serious injury if damaged.
Removal of the battery may require heat to soften the adhesive holding the battery to the phone chassis. Do not heat the battery if you suspect that the battery has been damaged in any way.
  1. Turn the device on  it side with the buttons away from you. Using the SIM Card Eject Tool, insert the narrow end into the ejection hole. Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. Pull the tray out with your fingers . Remove the SIM card. Remove the SIM card.
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. Remove the one T2 screw from the side of the phone near where the SIM card tray was.
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. Insert a plastic opening tool into the space where the SIM card tray used to be. Gently pry the back away form the phone frame until you hear and audible click of the back separating.
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Insert the plastic opening tool into the space you created between the phone back and frame. Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  7. Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable. Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  8. Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  9. Turn the phone over, with the screen up. Insert the opening tool between the screen and the silver trim that surrounds it.
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  10. Turn the phone back over, with the screen down. Lift the trim piece off of the phone and set aside.
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  11. Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard. Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
  12. Use a pair of tweezers to carefully pull up on the tape securing the connector. This will undo the connector as well.
    • Use a pair of tweezers to carefully pull up on the tape securing the connector.
    • This will undo the connector as well.
  13. Be careful to not damage the battery during this step. If it appears you are using too much force to separate the battery from the frame, you may need to heat the phone to soften the adhesive holding the battery to the phone. Starting at the bottom left corner of the battery, use the wide end of the spudger as a wedge to get underneath the battery. Insert a plastic opening tool into the space created by the spudger and CAREFULLY begin to pry around the edge of the battery.
    • Be careful to not damage the battery during this step. If it appears you are using too much force to separate the battery from the frame, you may need to heat the phone to soften the adhesive holding the battery to the phone.
    • Starting at the bottom left corner of the battery, use the wide end of the spudger as a wedge to get underneath the battery.
    • Insert a plastic opening tool into the space created by the spudger and CAREFULLY begin to pry around the edge of the battery.
    • Once the battery is separated for enough from the phone, use your hands to fully remove the battery, using the wide end of the spudger to scrape off adhesive where necessary.
Заключение
2 участников успешно повторили данное руководство.
Ronald Weimar
Участник с: 24.09.2018
988 Репутация
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 17
За 30 дней: 103
За всё время: 400
