Введение
You can use this guide if you have a cracked back cover for your ZTE Grand X Max Plus and want to replace it.
You can also use this as a guide to open your phone.
Выберете то, что вам нужно
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
After the phone is heated, use the blue plastic opening tool on both sides of the phone.
Carefully remove the cover from the phone.
Pics are a little dark. See if you can play with the white balance to correct this.
2 участников успешно повторили данное руководство.
What if you have no heating element or source
mlp100686 - Ответить
