Введение
If you have a dead battery and want to replace it, you can use this guide.
The guide will show you how to remove the back cover of the ZTE Grand X Max Plus and how to remove the battery.
Запчасти
No parts specified.
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
After the phone is heated, use the blue plastic opening tool on both sides of the phone.
Pull up the piece that is connected to the motherboard. You can pull it using your nails.
3 участников успешно повторили данное руководство.
