Введение
This guide shows you have to replace the LCD screen for the ZTE Jasper LTE phone. You might need to replace the screen if the screen is unresponsive to touch, the screen is cracked, or you have a dead screen.
Выберете то, что вам нужно
Insert the spudger into the bottom left corner of the phone.
Use the spudger to loosen the back cover.
Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
Continuing to use tool, prop up the battery and remove it.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
Remove the 0.8mm Phillips #00 screw from the bottom right.
Disconnect the gold pin by pulling upwards with the tweezers.
Lightly disconnect the power button, volume button and the chip from the motherboard.
Lightly move clip back to release the motherboard.
Gently pull the motherboard away from the screen.
2 человек успешно провели ремонт по этому руководству.
