Введение
This guide shows you have to replace the speaker for the ZTE Jasper LTE phone. You might need to replace the speaker if no audio or sound is distorted.
Выберете то, что вам нужно
Insert the spudger into the bottom left corner of the phone.
Use the spudger to loosen the back cover.
Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
Continuing to use tool, prop up the battery and remove it.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
Remove the speaker using the tweezers by gripping each side and pulling upwards.
