Введение
Follow this guide to perform the replacement of the motherboard on a ZTE Lever smartphone.
Выберете то, что вам нужно
Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
Remove the cover.
Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
Peel up the volume button cable from the phone with hands, or plastic opening tool.
Disconnect the power button from the motherboard with a plastic opening tool.
Peel the power button cable up from the phone with you hands, or a plastic opening tool.
Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
Один комментарий
Those are excellent instructions but I need to know where at on the motherboard is the internal memory storage cuz my phone is so screwed up that it won't charge or turn on or anything lol,so I got a different phone n got my SD card out of the ZTE n put in my new phone and there are some pics that I really need,but I was wondering if there was any way possible that I could put the SD card back in the ZTE motherboard and some how move the pics onto my SD card so I can have them on my new phone.This is killing my brain on trying to think of ways to succeed n can't please get back to me,,,thanks.
-ROGER-
