Введение
Follow this replacement guide to replace the power button on a ZTE Lever smartphone.
Выберете то, что вам нужно
Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
Remove the cover.
Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
Peel up the volume button cable from the phone with hands, or plastic opening tool.
Disconnect the power button from the motherboard with a plastic opening tool.
Peel the power button cable up from the phone with you hands, or a plastic opening tool.
