Введение
This guide has step-by-step instructions on how to replace or remove your ZTE Max XL SIM card tray. To determine if you need to replace your charging port refer to our Troubleshooting Guide.
Note: If the SIM card does not eject in the first step, you will have to complete the full removal guide.
Выберете то, что вам нужно
Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
Starting at one corner, wedge the plastic opening pick underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom, and 6 on each side.
There are two 3.4mm JIS 00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS 00 screwdriver.
After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver.
Use a plastic opening pick between the screen and side trim battery cover to remove the screen.
On the top left of the battery, flip the metal clips with a pick and remove the battery ribbon from the shell.
Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
Using the iFixit opening tools carefully pry the edges of the battery away from the casing.
With the battery removed, you can now insert the new battery or replace other parts within your phone.
Disconnect the six connections located on the large circuit board.
The camera itself is lightweight so take care during disconnection of the connector not to lose it.
With the circuit board removed, press the small button next to the SIM Card slot, this will cause the tray to pop out slightly. Remove the SIM card tray.
4 участников успешно повторили данное руководство.
2 Комментариев
My husband cell phone is a zte android and the plug in part was complelty not workimg so he took the back off and all that changed the usb plug in charger part and put his cell back together and it charges and it works besides when je gets on line like google it lets him on for just a swcond and then jt will say lost connection check your netwprk and we have unlimited high speed data is there something he might of accidently done wrong when he replaced the charging part please help
