Введение
Has your ZTE Quest’s rear-facing camera been badly scratched or damaged? This guide will provide instructions on how to replace your camera. All you need is a plastic opening tool, some tweezers, and a JIS #000 screwdriver.
Выберете то, что вам нужно
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
Pull back the tape encasing the brown ribbon cable connector.
Remove the ribbon cable from its socket.
Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
Flip the motherboard over and find the camera’s flat-top connector.
Gently pry up each side of the connector with a pair of tweezers before fully removing it.
Еще один человек закончил это руководство.
