Введение
Everyone likes to listen to music right? Then we need to learn how to get to the headphone jack if it needs to be fixed.
Выберете то, что вам нужно
Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
With the plastic opening tool the spudger, gently pry off the inner back.
Be careful not to pry it off too hard, as it is just a plastic covering.
Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
Using the spudger, gently pry up all ZIF connectors
ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
Using same spudger, gently pry up the orange flat top connector
