Введение
If the battery dies quickly, this replacement guide should help to make it function.
Выберете то, что вам нужно
Use a plastic opening tool to pry open the back case.
Use a Phillips #0 screwdriver to remove the eight 5mm screws.
Use a plastic opening tool to remove the midframe.
Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
Lift the battery up and remove it from the phone.
2 участников успешно повторили данное руководство.
