Введение
If the camera is showing a black screen or the camera does not take a picture.
  1. Pry open the back case to get to the back cover. Remove eight 5mm screws with a PH0 screw. Pry open  the  back cover with a plastic opening tool.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  3. Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable. Lift the battery up and remove it from the phone. Lift the battery up and remove it from the phone.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  4. Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable. Lift the front camera out of the phone.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
    • Lift the front camera out of the phone.
Заключение
2 участников успешно повторили данное руководство.
Dela Mohammed
Участник с: 18.10.2018
135 Репутация
1 Guide authored
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 69
